TwinTurbo.NET: Nissan 300ZX forum - Question, TPS switch continuity. Nissan Datascan
Subject Question, TPS switch continuity. Nissan Datascan
Posted by LJZTT on December 19, 2009 at 1:09 PM
  This message has been viewed 660 times.
Message When I have it the "closed TPS" parameter reads "off" or "on"?
When my TPS voltage reads .42v the "closed TPS" reads ON
When my voltage is adjusted to .46v the "closed TPS" reads OFF.
I'm confused which it is that I want, following this procedure trying to idle out a high idle as best I can with a known boost leak possibly under the lower plenum.
[ http://www.twinturbo.net/nissan/300zx/forums/technical/view/960871/How-to-test-and-adjust-your-TPS-switch-amp-sensor.html ]
click for photos by SnowmanZ
"The American people will never knowingly adopt socialism. But, under the name of "liberalism", they will adopt every principle of our socialist program, until one day America will be a socialist nation, without ever knowing how it happened.... I no longer need to run on the Socialist Party ticket because the Democrat Party has now adopted our platform."
--Norman Thomas, 1944 Socialist Party Presidential Candidate
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery."
--Winston Churchill
