TwinTurbo.NET: Nissan 300ZX forum - that'll work. However...
Subject that'll work. However...
Posted by ZEngineer on March 27, 2006 at 10:24 AM
  This message has been viewed 617 times.
In Reply To EFI Harness install using de-pinning method....(detailed) posted by Milo (San Antonio) on March 26, 2006 at 09:28 PM
Message I decided to try my luck by inserting the connectors without de-pinning them. After a few failed attempts, I found that by inserting the smaller connector (on the shorter end of the wiring) first, then once that makes it through, inserting the larger blue connector, I could have the harness through in a minute.
Others have also done this successfully and documented it on the Forum, too bad I had to learn the hard way.
_________________________________________________________________________________
"The Z is the cause and the solution to all my problems" -- Me
manstretch: well, my rear end is just worn out
ZEngineer24: sig quote
