TwinTurbo.NET: Nissan 300ZX forum - Well, hold in there for my variable backpressure exhaust
Subject Well, hold in there for my variable backpressure exhaust
Posted by Ash's Z on February 08, 2006 at 5:19 PM
  This message has been viewed 456 times.
In Reply To unfortunetly the midpipes are long gone. posted by SnowManZ on February 08, 2006 at 05:16 PM
Message system that should be available soon.
This exhaust system will have a butterfly valve in the exhast midpipe that is controlled with a wastegate actuator. This will be used to create backpressure on the engine when the engine is not boosting in order to benefit low-RPM torque production, but it will open up as soon as the engine begins boosting. With this device, it will apply the proper backpressure to the turbine shaft seal as well when you let out of the gas, which will prevent this form of leakage.
[ ashspecz.com ]
[ agpowers@bellsouth.net ]
Enthusiasts soon understand each other. --W. Irving.
Are you an enthusiast?
If you are out to describe the truth, leave elegance to the tailor.
Albert Einstein
