TwinTurbo.NET: Nissan 300ZX forum - correct. OEM uses a fixed, thin plate or bracket to hold
Subject correct. OEM uses a fixed, thin plate or bracket to hold
Posted by robo (sebring1970) on December 08, 2005 at 6:18 PM
  This message has been viewed 475 times.
In Reply To The new 300 degree camber kit must not use a plate on posted by Zirvana on December 08, 2005 at 08:40 AM
Message the two upper, upper control arm bolts together on the engine bay side. The 300 Degree Kit just gives you two loose bolts for replacement.
I looked at this a long time (at least 45 seconds, lolam) to make sure in my mind that this was not a compromise on the strength of the mod. The only problem I could foresee would be on the body sheet metal itself, where the bolts poke thru. But I've decided that's a non-issue, based on the total absence of failures reported for the kit. I think the shim itself more than makes up for the bracket. Clear as mud?
