TwinTurbo.NET: Nissan 300ZX forum - 2nd! One way it can be done is by removing fuel pump relay
doug8867
on December 05, 2005 at 9:12 AM
Add the part about relieving the fuel pressure first. (n/m)
posted by Woody75 (Denver)
on December 05, 2005 at 09:00 AM
located inside US driver's side kick panel. After removing, crank engine a few times to relieve pressure.
How to Replace Fuel Injector Using Dremel Method
robo (sebring1970)
07:15:43 12/05/05
Nice writeup! VTF (n/m)
Tom B (IN)
07:26:13 12/05/05
faqit! (n/m)
E=mz²
08:00:15 12/05/05
Woody75 (Denver)
09:00:00 12/05/05
2nd! One way it can be done is by removing fuel pump relay -
doug8867
09:12:23 12/05/05
Agreed. Although removing the fuel pump fuse
Luis (San Antonio)
16:07:06 12/05/05
ConZult has a feature for relieving fuel pressure
Tom B (IN)
22:45:24 12/06/05
good point. I didn't relieve any fuel pressure before
robo (sebring1970)
10:28:19 12/05/05
Big step
Mickie
11:41:14 12/05/05
hmmm, wouldn't that solve one of the hardest parts of
robo (sebring1970)
03:07:20 12/09/05
that's an awesome job of documentation...
Audioquest
09:42:18 12/05/05
How to Replace An Injector that NEEDS the Dremel Method...
thumper300zx
10:10:23 12/05/05
Yeah, I read this when I did #6 a month ago..thanks! (n/m)
Audioquest
10:53:16 12/05/05
I'm happy to have your article tag along in this FAQ
robo (sebring1970)
12:15:12 12/05/05
The cut off wheels works better with the dremel if...
Ashman2k2
18:28:43 12/05/05
Nice write-up but NO FAIR. These injectors already had the
jzack
18:33:53 12/05/05
Stock screws are very easy to remove if you use a both a
Julius
18:42:37 12/05/05
A manual impact wrench works great too!! (n/m)
Zirvana
13:08:01 12/06/05
curious, how/what kind of adjustable wrench can/do you
robo (sebring1970)
03:06:16 12/09/05
He's probably got a square shafted driver and uses...
thumper300zx
08:43:06 12/12/05
Several things....
sorka
02:27:43 12/06/05
yes, purists will always rec pulling the plenum.
robo (sebring1970)
20:25:46 12/06/05
look for any corrections to this article on my Web site
robo (sebring1970)
18:22:41 12/08/05
