TwinTurbo.NET: Nissan 300ZX forum - Driver or Passenger?
Subject Driver or Passenger?
Posted by RedShiftZ (KCMo) on May 09, 2005 at 11:18 PM
  This message has been viewed 229 times.
In Reply To Door panel removal with window stuck posted by Chaaarmndr (NoVa) on May 09, 2005 at 03:20 PM
Message If Driver door, pop the bottom of the panel loose, reach up under and unplug the connector from the window amplifier.
If passenger, unplug passenger window switch to get to the correct connector.
Then connect a hot and a ground to the correct wires to roll down the window.
I beleive the wires are blue/white and green. If it goes the wrong direction, reverse your hot and ground.
