TwinTurbo.NET: Nissan 300ZX forum - You can also try just burping the system. When car is
Subject You can also try just burping the system. When car is
Posted by jzack on February 21, 2005 at 6:17 PM
  This message has been viewed 180 times.
In Reply To You need to bleed the cooling system of air. Here's how: posted by sumonis on February 21, 2005 at 05:56 PM
Message cool remove radiator cap. Start engine and let idle -- just like the other post said -- set heater inside temp to 90 degrees. Once engine has warmed a bit gently squeeze the upper radiator hose. This forces air bubbles into the radiator and up thru the filler hole.
I always worry about removing the radiator bleed hole screw since my radiator is still original. Not looking to cause leaks, cracks or other issues there.
