TwinTurbo.NET: Nissan 300ZX forum - Flywheel resurfacing step
Subject Flywheel resurfacing step
Posted by RomChip200 on June 19, 2004 at 8:18 AM
  This message has been viewed 501 times.
0.008" step : does it mean the contact surface of the flywheel must be 0.008" higher than the clutch cover bolted-on surface ?
I don't know so much about the clutchs, and I bought an aftermarket clutch (Action clutch).
When you push the clutch pedal, what's the max distance the pressure plate moves ?
I were measuring the "standby" distance between the flywheel and the pressure plate, I got 5.25mm.
My 6 pucks disc is 8.2mm thick.
If I have a 0.2mm step (0.008"), it means the pressure plate must be disengaged for more than 8.2 - (5.25 +0.2) = 2.75 mm
Does it look correct ?
