| Message |
:The HICAS computer, next to the ECU, is 2 computers in one. PS and HICAS. Taking all the HICAS stuff off, except the computer, should only cause the HICAS lite comes on. Cut the wire going to the lite at the plug of the PS/HICAS computer. :You can't remove the computer unless you have huge arms. I looked at the computer on a NA but the plug if differant and looked like a hassle to swap and make work.Which plug goes to the hicas computer, the larger one or smaller one? I unplugged 1 of each and tried it with no luck. I also unplugged them both and still no luck. My TechTom MDM indicates the PS stator sw is always off? What can cause this if I have the hicas computer disco'd? I have also checked and verified the new NA line has the sensor connected and the Fuse is good. Gary
