TwinTurbo.NET: Nissan 300ZX forum - ptu values
Subject ptu values
Posted by joe_from_utah_300z on June 14, 2003 at 12:36 AM
  This message has been viewed 718 times.
Message Hello everyone many moons ago i was having some trouble with the z and i wanted to check out the ptu, problem was the values in the 1990 manual are for the old type of unit and as a result very off. To make a long story short my problem was not with the PTU but rather one of my coil packs not being plugged in and the connection at the ecu was crooked after i had installed an airfuel ratio gauge which disabled spark to the other cylinder. However i thought it may be a good idea to provide the GOOD PTU values measured in ohms and on the diode setting, i used two different meters just to give you an idea of what you'll see one meter is fairly inexpensive (5.00 at harbor freight) and the other is about $45.00 at a local electronic shop(this one is the one i trust more because the junction gap between most transistors is in the range of .400-.700. You can see this on my webpage at Click Me
Joe a.k.a WiGgY a.k.a WiGgLEs a.k.a wAgGans
presented by jOe WiGgInS a.K.a. wIgGy
TABLE 1 All of these values in the above table where taken using a BK TOOL
KIT METER model 2703B multimeter on the DIODE setting
TABLE 2 These Values were obtained with the CEN-TECH P35761 meter (a.k.a
Harbor Freight Meter) on the diode setting
Table 3 No values obtained on either meter both on ohms and diode
setting
TABLE 4 values are indicated as follows 627/.401 first number is CENTECH
meter, second number is BK TOOL KIT METER and first row of numbers is diode
setting, the next row is ohms(both meters same values)
Negative LEAD
TABLE 1 BOTTOM PINS 123G456 Positive Lead
1
2
3
G
5
6
7
E1
0.419
0.516
0.516
0.403
0.516
0.516
0.516
E2
0.516
0.418
0.516
0.402
0.516
0.516
0.516
E3
0.516
0.516
0.417
0.401
0.516
0.516
0.516
E4
0.514
0.514
0.514
0.401
0.416
0.514
0.514
E5
0.514
0.514
0.514
0.397
0.514
0.415
0.514
E6
0.514
0.514
0.514
0.397
0.513
0.513
0.415
Negative LEAD
TABLE 2 BOTTOM PINS 123G456 Positive Lead
1
2
3
G
5
6
7
E1
715
1415-1430
1415-1430
649
1415-1430
1415-1430
1415-1430
E2
1415-1430
716
1415-1430
651
1415-1430
1415-1430
1415-1430
E3
1415-1430
1415-1430
716
650
1415-1430
1415-1430
1415-1430
E4
1415-1430
1415-1430
1415-1430
660
724
1415-1430
1415-1430
E5
1415-1430
1415-1430
1415-1430
662
1415-1430
725
1415-1430
E6
1415-1430
1415-1430
1415-1430
666
1415-1430
1415-1430
736
Table 3
E1
E2
E3
E4
E5
E6
Ground
No Value
No Value
No Value
No Value
No Value
No Value
Someone please buy my corvette look at all these nice Pictures
"I.Q. is enviromentally influenced BUT genetically limited"
"without failure you can't appreciate success" - nicolas cage
Negative LEAD
TABLE 4 BOTTOM PINS 123G456 Positive Lead
1
2
3
G
5
6
7
Ground
627/.401
627/.401
627/.401
627/.401
627/.401
627/.401
627/.401
diode
Ground
631
631
631
631
631
631
631
ohms
