TwinTurbo.NET: Nissan 300ZX forum - MAFS screens (what they do)...
Subject MAFS screens (what they do)...
Posted by dbotos on April 23, 2003 at 6:00 PM
  This message has been viewed 166 times.
In Reply To I thought it caused turbulence, for a better airflow reading posted by Kez43 on April 23, 2003 at 01:20 PM
The upstream MAFS screen is there to reduce turbulence (both axial and radial) in order to provide a more uniform, aligned flow passing over the hot film sensor element, producing more accurate mass flow readings. The screen itself does cause a slight amount of turbulence, but the overall effect is a reduction.
The downstream screen again conditions the flow before it passes on to the rest of the intake system. The primary reason for this being that the sensor support is a somewhat large, irregular flow obstruction:
If you want to learn more about flow conditioning using screens and/or honeycomb sections, see if you can find this book or other books on wind tunnel design at the library. On a related note, I am currently working on designing the flow conditioning section of a cascade wind tunnel that runs at Mach 0.85 in the test section and about 25 m/s in the flow conditioning section, which will contain 4-5 screens and a 2"-thick section of aluminum honeycomb.
"The more "F" and the less "m" you have, the more "a" you can get." -- Brian Beckman, The Physics of Racing
