TwinTurbo.NET: Nissan 300ZX forum - pressure is dead on. normal. no smell of oil or gas in fluid
nixit(da][as)
on October 09, 2002 at 3:23 PM
oh yeah "symptoms": low oil pressure is one. (n/m)
posted by Halo Z
on October 09, 2002 at 03:22 PM
no PCM error codes either.
just a noise. an ugly noise all beit. especially under boost.
whats the symptoms of a spun bearing?
nixit(da][as)
15:14:57 10/09/02
retighten your pass side down pipes again? (n/m)
Halo Z
15:21:26 10/09/02
Halo Z
15:22:17 10/09/02
pressure is dead on. normal. no smell of oil or gas in fluid -
nixit(da][as)
15:23:32 10/09/02
pull coil packs, one by one, see if it's verys per cyl. (n/m)
Halo Z
15:26:08 10/09/02
good idea. I was thinking "wrist pin" with this diagnosis.
nixit(da][as)
15:37:05 10/09/02
might just be the turbo it's self. time to upgrade (n/m)
Halo Z
15:39:47 10/09/02
Time for TD-05's! (n/m)
Kenny (9 psi TT + NA)
15:41:03 10/09/02
nope. JWT 500s. unless they make a TD-01.
nixit(da][as)
15:46:36 10/09/02
people that blame the president for our problems
joel(PA)
16:34:47 10/09/02
don't start. (n/m)
Halo Z
16:52:17 10/09/02
sorry =P (n/m)
joel(PA)
17:10:58 10/09/02
Remember that night at the zcon? boy, i was a scared
nixit(da][as)
15:52:45 10/09/02
now you got me thinkering...
nixit(da][as)
16:03:31 10/09/02
so you have had this noise for over 1k?
Halo Z
16:23:12 10/09/02
possible cracked rod cap??? (n/m)
SacTown-TTZ
16:25:20 10/09/02
yea. not necessarily the same noise this time. (n/m)
nixit(da][as)
15:22:21 10/09/02
Online info>>>>
15:25:54 10/09/02
Thanks Kenny
nixit(da][as)
15:36:17 10/09/02
No prob. =)
15:40:01 10/09/02
we are still prototyping everything...
nixit(da][as)
15:58:00 10/09/02
David? he okay? (n/m)
Guapo
16:55:16 10/09/02
Sounds like it could be a rod knock...
SacTown-TTZ
15:46:10 10/09/02
Agreed, sounds very much like it could be a rod knock...>>>
5150Z
11:06:34 10/10/02
spun rod bearing almost always lowers oil psi
AntiHero[seatbelts rock]
17:08:57 10/09/02
Sweet. not a spun rod bearing then.
nixit(da][as)
18:00:13 10/09/02
I ran mine like that nearly a year at stage III. :)
DamonH 90TT
17:59:15 10/09/02
if its rod a bearing going bad...
aliaZ
22:51:46 10/09/02
When I spun my #1 rod bearing it was just a clunk>>
dilly yo
04:56:53 10/10/02
