TwinTurbo.NET: Nissan 300ZX forum - Yeah I can understand that BUT >>>
Subject Yeah I can understand that BUT >>>
Posted by Greg (Dallas) on September 27, 2002 at 1:18 PM
  This message has been viewed 148 times.
In Reply To As far as the boost leak, I had a large hole (dime size) posted by aZiator on September 27, 2002 at 10:40 AM
Message You can still build target boost w/ a leak as long as the turbos are strong enough. They're just working a lot harder than they should (and running hotter).
BUT, I would think that, if fuel pressure is controlled by manifold pressure (which it is from a control standpoint) that you shouldn't end up with such a bizarre disparity (manifold shows X, fuel pressure drops totally out of sync) if it was due to a boost leak. I would expect that either boost wouldn't be as high, but the ratio of the two should still be constant. Yes? No?
I'm so lost... and I miss boost. On the up side it still feels pretty strong going up to 7-8psi and shutting down before the fuel pressure can drop.
Meddle not in the affairs of dragons,
for you are crunchy, and good with mustard.
Mr. K gets it!
