TwinTurbo.NET: Nissan 300ZX forum - Re: sounds like a faulty EGR system..probably a valve stuck open
Subject Re: sounds like a faulty EGR system..probably a valve stuck open
Posted by got rice? on June 06, 1999 at 7:54 PM
  This message has been viewed 35 times.
In Reply To Re: sounds like a faulty EGR system..probably a valve stuck open posted by XTA Z on June 06, 1999 at 07:48 PM
: I have run a ECU test.......code 55. Also did the individual test for each O2 sensor.....nothing. I will check out the EGR valve though. Thanks.
the ECU diagnostic doesn't always show a bad o2. the best way to find out is to find the voltage on each o2 sensor.
later,
Phuong (got rice?)
