TwinTurbo.NET: Nissan 300ZX forum - Re: Injectors 1 and 2 not firing
Subject Re: Injectors 1 and 2 not firing
Posted by Zxpress on June 01, 2026 at 8:04 AM
  This message has been viewed 14 times.
In Reply To Injectors 1 and 2 not firing posted by ctheobal on May 29, 2026 at 07:29 PM
Message Test the injector at its prongs with a 9v battery. Polarity doesn't matter. It will click if it's working properly. If it clicks, then reconnect and try the same test through the harness. Pin 58 is the common positive. The grounds are as follows:
Test one that you know is working to be sure you're correctly doing this.
FI #1 - 101
FI #2 - 110
FI #3 - 103
FI #4 - 112
FI #5 - 105
FI #6 - 114
