TwinTurbo.NET: Nissan 300ZX forum - 2nd,.Check T-belt first. Numbers are too strange. (n/m)
ttz'in (NorCal)
on November 16, 2010 at 1:22 AM
Bend valve or timing timing is off just enough.
posted by Draker (Eugene, OR)
on November 15, 2010 at 09:08 PM
Compression test results.
SlowZ(SD)
16:12:19 11/15/10
Re: Compression test results.
txq45
18:19:03 11/15/10
I had 0psi... found a bunch of these.. (see pic)
Hoppy2
06:59:17 11/16/10
yup that is what i am expecting to find (n/m)
SlowZ(SD)
09:52:47 11/16/10
SlowZ(SD)
01:54:03 11/17/10
Before you go too crazy here - have you verified that
jzack
18:21:25 11/15/10
compression gauge is good.
SlowZ(SD)
00:52:36 11/16/10
Draker (Eugene, OR)
21:08:54 11/15/10
2nd,.Check T-belt first. Numbers are too strange. (n/m) -
ttz'in (NorCal)
01:22:20 11/16/10
I like the idea of timing being just a little of.
SlowZ(SD)
01:26:11 11/16/10
If your timing belt is off some teeth, it means that a valve
MixManMash
08:29:09 11/16/10
Well thank you all guys. This discussion was very helpful.
SlowZ(SD)
14:23:04 11/17/10
