TwinTurbo.NET: Nissan 300ZX forum - Re: Compression test results.
Subject Re: Compression test results.
Posted by txq45 on November 15, 2010 at 6:19 PM
  This message has been viewed 173 times.
In Reply To Compression test results. posted by SlowZ(SD) on November 15, 2010 at 04:12 PM
Message To get a 0 psi you have to have bent valves, burnt valves, hole in piston. Even a worn out engine it will have compression above zero.
Usually 60-100 is burnt ring lands..
Nistune Dealer
Dyno Tuning
ECU socketing ECU eprom upgrade
http://www.AAA-HiperformanceAuto.com
