TwinTurbo.NET: Nissan 300ZX forum - Tried it several times, and from multiple locations
Stadsport (PHX)
on September 25, 2010 at 6:14 PM
Flip your signal pick up 180 degrees (n/m)
posted by Bernie (NoVA)
on September 25, 2010 at 06:09 PM
PTU loop, coilpack connector, and high-tension wire as per the FSM.
Timing is possessed.
Stadsport (PHX)
22:46:45 09/24/10
Check your woodruff key
Jehannum
10:12:01 09/25/10
Re: Check your woodruff key
Stadsport (PHX)
12:00:58 09/25/10
Since you have a 1990 z
ArubaDave
10:36:49 09/25/10
I have looked into this problem
Stadsport (PHX)
12:05:01 09/25/10
Intake cam gear going bad or vtc solenoids (n/m)
John (MD)
20:15:04 09/28/10
Are there any differences in the timing readings between
DVDBURN (MD)
17:24:24 09/25/10
Re: Are there any differences in the timing readings between
Stadsport (PHX)
17:28:13 09/25/10
When you put in a non-modified CAS and place the mounting
DVDBURN (MD)
17:40:37 09/25/10
15 degrees, that's where it's at now. (n/m)
Stadsport (PHX)
18:01:40 09/25/10
Have you tried a different ECU?
DVDBURN (MD)
18:35:25 09/25/10
Re: Have you tried a different ECU?
Stadsport (PHX)
19:42:28 09/25/10
I would try a different ECU.
DVDBURN (MD)
08:49:04 09/26/10
18:09:29 09/25/10
Tried it several times, and from multiple locations -
Stadsport (PHX)
18:14:18 09/25/10
Tentative solution
Stadsport (PHX)
21:00:13 09/26/10
Replaced the key & reinstalled, didn't make any difference. (n/m)
Stadsport (PHX)
20:06:31 09/27/10
