TwinTurbo.NET: Nissan 300ZX forum - Re: Are there any differences in the timing readings between
Subject Re: Are there any differences in the timing readings between
Posted by Stadsport (PHX) on September 25, 2010 at 5:28 PM
  This message has been viewed 170 times.
In Reply To Are there any differences in the timing readings between posted by DVDBURN (MD) on September 25, 2010 at 05:24 PM
Message The ECU (Consult, Nissan Datascan, etc) always indicates 15 degrees under the conditions I've tried to adjust. I always test it once it's warmed up. When you rev the engine, you can see it move around on the ECU side and the light side. It's just skewed ~40 degrees, as you can see from the light.
