Timing is possessed. posted by Stadsport (PHX) on September 24, 2010 at 10:46 PM
using the timing light and using consult? In other words, when you adjust the timing with your modified CAS and it indicates 15 at the crank does it also indicate 15 with consult? Or is there a difference?
