TwinTurbo.NET: Nissan 300ZX forum - I have looked into this problem
Subject I have looked into this problem
Posted by Stadsport (PHX) on September 25, 2010 at 12:05 PM
  This message has been viewed 176 times.
In Reply To Since you have a 1990 z posted by ArubaDave on September 25, 2010 at 10:36 AM
Message And everything I've read indicates that this problem can cause the timing to jump around a little bit and wear out CASs, and cause the timing to advance or retard as much as 6-8 crank degrees (as indicated in the PDF). The timing is completely stable, just indicated ~40 degrees off.
On top of that, the engine was replaced before I bought it.
