TwinTurbo.NET: Nissan 300ZX forum - So I Ran An A/C Test - Results
Subject So I Ran An A/C Test - Results
Posted by Z32 TwinZ on August 19, 2010 at 7:30 PM
  This message has been viewed 376 times.
In Reply To You have auto. posted by arkansasturbo on August 18, 2010 at 04:35 PM
Message [ http://www.ttzd.com/tech/autocctech.html ]
ok so i went through the test and here are the results.
Monitor Diagnosis Mode:
Def icon only Ambient temperature ºC(ºF) -"87"
Upper vent icon only Upper cabin temperature ºC(ºF) -"00"
Lower vent icon only Lower cabin temperature ºC(ºF) -"99"
0 Fan & Def icon DEFROST outlet air temperature ºC(ºF) -"04"
0 Fan & Upper vent icon VENT outlet air temperature ºC(ºF) -"04"
0 Fan & Lower vent icon FOOT outlet air temperature ºC(ºF) "00"
1/4 Fan & Def icon Sunload *1 -"06"
1/4 Fan & Upper vent icon water temperature *3 ºC(ºF) -"68"
1/4 Fan & Lower vent icon Mode door voltage *4 *2 -"02"
1/2 Fan & Def icon N/A -"00"
1/2 Fan & Upper vent icon N/A -"53"
1/2 Fan & Lower vent icon N/A -"53"
3/4 Fan & Def icon N/A -"30"
3/4 Fan & Upper vent icon N/A -"42"
3/4 Fan & Lower vent icon N/A -"68"
Full fan & Upper vent icon Difference in upper & lower temperatures ºC(ºF) -"00"
Full fan & Lower vent icon N/A -"05"
Actuator Test Mode:
Defrost icon - Mode door - DEF, DEF/Lower, B/L, VENT - "48"
Defrost and lower vent icon - Intake door - FRE, FRE, 50% FRE, REC - "31"
Upper and lower vent icon - Air mix door - Full hot,Full hot, 30ºC(86ºF), Full cold - "13"
Upper vent icon - Compressor - OFF, OFF, ON, ON - "1"
Upper and Lower Temperature Difference Mode:
ºF spec. Data -36 to -2 0 2 to 36
ºF spec. Difference between upper and lower target temperatures -3.6ºF to -0.2ºF 0 0.2ºF to 3.6ºF
"-35,-34,-33,-30,-29,-27,-25,-24,-21,-20,-18,-16,-15,-12,-11,-9,-7,-6,-3,-2,00,02,03,06,07,09,11,12,15,16,18,20,21,24,25,27,29,30,33,34,36"
Trouble Codes:
No codes were given
