TwinTurbo.NET: Nissan 300ZX forum - Re: wiseco piston rings on oem pistons.
Subject Re: wiseco piston rings on oem pistons.
Posted by txq45 on August 17, 2010 at 8:13 PM
  This message has been viewed 336 times.
In Reply To wiseco piston rings on oem pistons. posted by Andrewhuffman on August 17, 2010 at 03:34 PM
Message I assume this is not a built block?
If you can debur the coolant gallery out while you have it down you would benefit from doing so.
Manufactures usually match up their pistons and rings. I know you can get +01 rings for the Weisco pistons not sure about the OEM>
Don't use 1 (88mm) size larger rings their not made for what you purpose, but if the cylinders are still stock you could use the +01 stock oversize.
I suspect you'll be running above stock boost which means a larger gap anyway..
Nistune Dealer
Eproms and ECU socketing
Transmissions built for TT, Skyline, 240 ..
http://www.aaa-hiperformanceauto.com
