TwinTurbo.NET: Nissan 300ZX forum - Good info. Thanks!
Good info. Thanks!
earthpunk
on August 08, 2010 at 7:46 PM
I heard a very small leak on around the EGR when
posted by Gordo 93TT Daytona
on August 08, 2010 at 01:55 PM
:performing my most recent boost test. The test pressure dropped about seven seconds per pound. It took about 35-40 seconds to drop from the 6 - 7 lbs of pressure used for the test.
Pressure Test / Leak Test Reveals leak at EGR valve...
earthpunk
02:50:28 08/05/10
how much pressure did you apply? about 5psi is enough. (n/m)
tognot
15:13:06 08/05/10
Re: how much pressure did you apply? about 5psi is enough.
earthpunk
20:22:03 08/05/10
The EGR leaks very little around the valve stem by design
Zarcasm(Hfd, CT)
22:01:24 08/05/10
Re: The EGR leaks very little around the valve stem by design
earthpunk
11:35:24 08/06/10
Re: Re: The EGR leaks very little around the valve stem by design
earthpunk
02:39:37 08/08/10
Gordo 93TT Daytona
13:55:34 08/08/10
Good info. Thanks! -
earthpunk
19:46:09 08/08/10
