TwinTurbo.NET: Nissan 300ZX forum - Probably the Air regulator sticking.
Subject Probably the Air regulator sticking.
Posted by Spddracer on July 16, 2010 at 4:24 PM
  This message has been viewed 241 times.
In Reply To Intermittent high idle... posted by thumper300zx on July 15, 2010 at 11:59 AM
Message This is the longer tube looking valve with a 2 prong connector on the back of the plenum (drivers side)
After warm and idle is up on it tap on this with something, If the idle drops the valve is either sticking or has no power and ground and/or the connector is corroded on it and not allowing it to heat up and close the window inside in which is keeping your idle up.
www.Zspeedperformance.com
