| Message |
:There is a starter relay under the drivers side fender, & there's a safety switch behind the clutch pedal linkage ( under the dash ) .. :IF the switch isn't closed, no crank. If the relay doesn't close, no crank.. :Check those two first... :Mikealright thanks Mike, i'll try that.
