Use anti-seize compound on the unthreaded part of the stud shaft and use a high quality 12.9 nut. Also but anti-seize on both sides of the undernut washer.
You could also put the studs (and nuts) in the freezer for several hours and work quick on the install. Remember that you are talking an interference fit of less than .002 inch.
