TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Climate control pod doesn't control heat/ac (or light up)
Subject Re: Re: Re: Climate control pod doesn't control heat/ac (or light up)
Posted by SPeedyZman on May 22, 2010 at 9:45 AM
  This message has been viewed 248 times.
In Reply To Re: Re: Climate control pod doesn't control heat/ac (or light up) posted by SPeedyZman on May 21, 2010 at 06:22 PM
Message Tracked the issue down to a poorly connected fuse in the fuse block in drivers foot well.
All fuses tested good w/continuity tester so I thought all was good.
After resulting to moving wires and such while viewing the pod to see if it came on..... finally found a 30am fuse that was the culprit. When it moved just a small amount it would turn off the pod (even though it was plugged in).
I still gotta check the servos on the heater box though..... as it was blowing hot heat ALL the time.
Figured I'd write this in here so I can refer to it later if I forget what happened, or someone else has a similar problem.
This was on a Red Z32TT that I converted from auto to 5spd (hard to keep track of Zcars sometimes ;o)
