TwinTurbo.NET: Nissan 300ZX forum - Or the fork is on wrong, TOB is not all the way on the sleev
Subject Or the fork is on wrong, TOB is not all the way on the sleev
Posted by Spddracer on May 13, 2010 at 4:29 PM
  This message has been viewed 121 times.
In Reply To And this is the next test........ posted by Greg D. (Specialty-Z) on May 13, 2010 at 01:21 PM
Message fork is bent/cracked, Pressure plate bolts are loose ect. There are many other things that can cause it, doesnt automatically mean the clutch is bad because this test failed.
However I do like this way of checking it, It will tell you immediately if the pedal is adjusted wrong and fluid is not going back into the reservoir and holding pressure against the pressure plate.
www.Zspeedperformance.com
