TwinTurbo.NET: Nissan 300ZX forum - thats REALLY rich, especially after the cats. to check ..
Subject thats REALLY rich, especially after the cats. to check ..
Posted by tognot on January 19, 2010 at 11:42 PM
  This message has been viewed 89 times.
In Reply To rich idle problem, need some direction posted by de944 on January 19, 2010 at 06:21 PM
Message for a injector leak you need to see if fuel pressure bleeds off while car is not running. Tee a gauge after fuel filter ( temporary) then key on. thats you pressure. key off, see if pressure stays there. if it drops quickly - you are leaking some where.
beyond that, are o2 sensors working when you do the self test on the ecu? coolant temp sensor in specS? if the ecu "sees" cold temps you will run rich
