I have a 90tt which I just finished putting a fresh engine rebuild in with tons of other new parts. I have a new rps 6 puck, new trans mount and low mileage driveshaft (oem). Also installed a C's short shifter which was fine when used on my other z. Heres the problem, when I'm driving (most notably when I put slight pressure forward on the shifter) and give and let off the gas (slightly jerking the car), the shifter jolts back. It seems to have some play in it, but definitely seems like its coming from the trans because the car has a slight clunk. Rear diff mounting seems solid too. Put it on the lift, nothing noticeable. All I know is that its not normal having driven others. Trans has about 100k on it. Any thoughts appreciated.
Trans problem... can't get find any answers. - Jkova300z17:57:43 01/13/10
