TwinTurbo.NET: Nissan 300ZX forum - Checking the VTC cam gears >>>
Subject Checking the VTC cam gears >>>
Posted by LitlElvis on December 31, 2009 at 1:17 PM
  This message has been viewed 164 times.
In Reply To trying to find oil leak...need some help posted by Adamo on December 29, 2009 at 07:55 PM
Message You will need to remove the VTC gears to be able to check them.
The "back plate" is the part that interfaces with the cam seal in the head. Clean the back plate and then hold it with a latex glove on your hand to get a good grip. Spin the entire gear with the other hand and see if you can prevent the "back plate" from spinning with it. If you can keep it from spinning, the internal o-ring seal is likely ruined and this is the most likely source of the oil leak.
