TwinTurbo.NET: Nissan 300ZX forum - Just line up each the 5 lines on the belt with the each of
Audioquest
on December 30, 2009 at 8:34 PM
Need timing belt help!
posted by JonnyZ(SoCal)
on December 29, 2009 at 10:19 PM
the dots on the cam and crank gears and it will be in time. Ignore the marks on the backing plates as they are only reference and will not line up 100% with the gear dimples with the belt installed correctly.
JonnyZ(SoCal)
22:19:04 12/29/09
TDC is 0deg (n/m)
Fast300
22:47:13 12/29/09
Thats what i thought, i guess my lower timing cover is off
JonnyZ(SoCal)
23:04:24 12/29/09
There is a dot (indent) on the crankgear - that lines up
jzack
22:57:46 12/29/09
So when the gears are all lined up its supposed to be TDC?
JonnyZ(SoCal)
23:06:01 12/29/09
Needs to be at O degrees for TDC but the #1 pistion >>>
ZUL8TR
08:06:17 12/30/09
Just line up each the 5 lines on the belt with the each of -
Audioquest
20:34:36 12/30/09
Zweet so I got it right then. The cam gears are lined up
JonnyZ(SoCal)
22:25:20 12/30/09
The marks on the backing plate need to line up >>
ZUL8TR
07:34:39 12/31/09
