TwinTurbo.NET: Nissan 300ZX forum - Sounds like a problem with the air regulator which supplies
Subject Sounds like a problem with the air regulator which supplies
Posted by doug8867 on December 30, 2009 at 3:19 PM
  This message has been viewed 116 times.
In Reply To VERY cold out ..car started and stalled - now won't restart posted by Andy_M on December 30, 2009 at 01:58 PM
Message excess air at start up. This would seem to jive with your symptoms going
away once the car warms up. Anyway, might check to see if there is
corrosion on the light blue connector located on the AAC at the back
driver's side of engine, and if so clean it off or replace the connector if it is
really bad. Also check for cracked or loose hoses coming off that device
and replace as necessary.
Your immediate problem does sound like it's flooded. Give it a few hours
and then try it again. Good luck.
