TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Idle Problem
Subject Re: Re: Idle Problem
Posted by SR707DRIFT on December 25, 2009 at 3:34 PM
  This message has been viewed 129 times.
In Reply To Re: Idle Problem posted by CmyZ on December 25, 2009 at 10:23 AM
Message No check engine lights. Only super hicas light. I found a fair amount of
corrosion on the injector plugs and when I did the Ohms reading it took a
while to get a reading but when I did they came out fine. There was a lot
of corrosion on the spark plug coil connectors to. Also when I got the car
the gas light was on with that old fuel so I drove to the gas station and
barely made it and filled it up with 91 octane, So wouldnt that have
deleted the old fuel and I dont need to flush out my gas tank? Also i'll
replace the fuel filter, spark plugs and clean all connections with
electrical connection cleaner next and I'll let you know how things turn
out. I've got to do a lot of researching on where some of these parts like
fuel filter, egr valve, tps and others are located so I can check them.
Heres everything I've done so far to try and get my car running good:
Changed oil
Flushed coolant
Replaced coolant
Ohm tested fuel injectors
Disconnected and reconnected all fuel injector and spark plug coil
connectors to make sure they were on snug
Disconnected fuel pump fuse, checked it then reconnected it
I'm going to do a compression check but the motor that's in my car was
installed by a shop and they checked the motor before installation. But
that was 2 years ago.
Also I don't have a boost leak because my turbo spools perfectly and
goes to 9.5 psi no problem. It's got new turbos as of 4 months ago.
