Idle Problem posted by SR707DRIFT on December 25, 2009 at 02:36 AM
Basically what WazTTEd indicated, apparently it has not been take care of.. Go thru the basics and you should be fine. Any lights on, as in check engine light? Start with cleaning all the connections or splicing in new connectors for the fuel injectors, change fuel filter, spark plugs and go from there. Also check the idle air control valve connectots on the rear of the intake, these also get the green corrosion..might need to replace those connectors.
