So my car is idling weird. I bought this car with year old gas in it that was ran to the gas light, the coolant was horrible and it was a rust orange color, oil wasn't in best shape either. I put new gas in it, new oil, and new coolant, but heres the problem I try and start my car and it takes a couple of turns to get the motor running. Once it's running it idles at around 1k rpm's pretty steadily. then it starts dropping and vibrating and wanting to die. It never use to die but today it was idling for about 30 seconds then it dropped to like 300 rpm's and died. I thought it was my fuel injectors so I tested them with a multi meter. Also it hasn't done this lately but it sometimes drops in idle when you lightly press on the gas.This is how the end results were: Injectors: #1 - 12.6 ohms #2 - 12.7 ohms #3 - 12.8 ohms #4 - 12.7 ohms #5 - 12.7 ohms #6 - 12.7 ohms And I was reading that anywhere from 10-14 ohms is fine. So now I don't think it's my injectors. Tomorrow I'm going to check the ohms on my spark plug coils which should be anywhere from 0.7 - 1.6 ohms And I'm going to check and replace my spark plugs as well. What else should I check to fix this problem? Thanks.
