The stock compressor A/R is .48 just like in the pic and the orientation of the inlet flange looks right. There should be a number etched into the turbine side, look just inside of the rear side of the exhaust inlet flange and you should see a .54 or .63 if it's a stock turbo. There should also be a tag on the center section and some numbers on the back of the exhaust housing.
