TwinTurbo.NET: Nissan 300ZX forum - Re:follow up- installed another MAF and ran much better
tognot
on December 24, 2009 at 1:39 PM
misfire\backfire\intermittent 91 tt stageIII
posted by tognot
on December 23, 2009 at 11:37 PM
i will add the car "felt lean" when symptoms were showing, such as you gave more throttle, car sputtered and slowed , as you let back off throttle, clean out and sped up.
we'll see how long this lasts!
tognot
23:37:02 12/23/09
Re: misfire\backfire\intermittent 91 tt stageIII
Dane (Houston)
01:29:40 12/24/09
Re: Re: misfire\backfire\intermittent 91 tt stageIII
paintballkustoms
02:35:15 12/24/09
injectors - cant hurt - i'll check them - AGAIN-thanks (n/m)
tognot
10:05:16 12/24/09
Re: thanks - test pipes are on there now to eliminate
tognot
10:01:45 12/24/09
The Silent Genius
09:26:40 12/24/09
Re: CAS- I hope not , but I will clean CAS connecters
tognot
10:03:46 12/24/09
Re:follow up- installed another MAF and ran much better -
tognot
13:39:48 12/24/09
daBAYisindaAREA
15:20:25 12/24/09
follow up II. problem still there - took a drive- had to ..
tognot
19:52:15 12/24/09
have you....
The Silent Genius
23:12:47 12/24/09
i am not home today- but have car with me-so i disc-
tognot
10:37:35 12/25/09
cleared ecu - drove 90 miles (barely) got a code 33 (n/m)
tognot
01:02:52 12/27/09
Re: cleared ecu - drove 90 miles (barely) got a code 33
The Silent Genius
11:56:11 12/27/09
yes, left bank is lean . new oem o2 on that side (n/m)
tognot
16:59:27 12/27/09
