Ok thank you. My engine has quote and quote 45k miles because it was bought from a shop and installed by them. It isn't a jdm motor it's a usdm motor. I've done searching but I just wanted to get others opinions. Another thing that wasn't added is that when I got the car it had old gas in it and it ran to the gas light when I bought it which makes me believe it clogged the injectors. And the oil is original oil from the day the motor was swapped in. So right after I bought it I put new gas in it as well as fuel injector cleaner. And then did an oil change. After the oil change I noticed it was running better and the idle stayed at close to a grand. But then after about 2 minutes of idling it started being jumpy. I'm going to check the ohm's on the injectors either today or tomorrow to make sure there good.
