TwinTurbo.NET: Nissan 300ZX forum - The wire harnesses that support the TCU are the primary
Subject The wire harnesses that support the TCU are the primary
Posted by LitlElvis on December 23, 2009 at 11:18 AM
  This message has been viewed 105 times.
In Reply To Swapping a manual transmission for an auto posted by inferno on December 22, 2009 at 05:04 PM
Message problem with trying to swap an OE automatic into a OE manual chassis. I don't believe anyone has done this "reverse" swap due to the rewiring nightmare it requires. If you absolutely want to use a RE4R03A automatic, it would probably be cheaper to find a OE automatic chassis.
The TH400 will swap in directly without wiring issues. Although it does not have an OD gear.
I finally have the 4L80E bellhousing adapters finished, but the rest is yet to be developed (crossmember, dipstick/filltube, speed sensor). The 4L80E can be built as a non-electronic, stand-alone transmission which will easily swap. TCI recently released a manual shift valve body with trans-brake for the 4L80E.
