| Sorry about that ,jumped the gun on that. Normally everyone swaps a 5 speed for an auto.. its the opposite and you will need the wiring which is different and the shifter, with its ignition key lock out cable and solenoid. If you are going that route get an automatic car you can get all the parts from. You will need to change the EGi wiring harenss also for an automatic one. Automatic radiator or install a aftermarket oil cooler for the auto tranny. Automatic brake pedal and switches.
