TwinTurbo.NET: Nissan 300ZX forum - Re: Need help please...injectors
Subject Re: Need help please...injectors
Posted by CmyZ on December 23, 2009 at 12:11 AM
  This message has been viewed 80 times.
In Reply To Need help please...injectors posted by Racedaily on December 22, 2009 at 09:47 PM
Message Polarity is not an issue, so you should be fine there.. Check your cas connector and PTU connector, jiggle them a bit.
Also make sure you installed the chip in the ECU in the correct postion. The notch on the Eprom (chip) goes towards the out side of the board. Try that. Make sure you have fuel.
