TwinTurbo.NET: Nissan 300ZX forum - Count the teeth between the marks- details inside
Subject Count the teeth between the marks- details inside
Posted by ThunderZ on December 21, 2009 at 9:33 PM
  This message has been viewed 518 times.
In Reply To Timing check Please posted by TRdave on December 21, 2009 at 08:38 PM
Message There should be 24 between passenger side cam marks not including the marks, 45 between passenger intake cam and driver intake cam marks not including the marks, 24 between driver side cam marks not including the marks, and 59 between the crank mark at 5 o'clock and the driver exhaust cam not including the marks.
You should be able to do this w/out removing the belt again, unless your tooth count is off, then you have to remove it anyway.
