TwinTurbo.NET: Nissan 300ZX forum - Some background here may be worth reading
Subject Some background here may be worth reading
Posted by Tom B (AZ) on December 21, 2009 at 9:02 AM
  This message has been viewed 90 times.
In Reply To Re: Automatic Transmission Issues. Help please! posted by txq45 on December 18, 2009 at 06:28 PM
Message The TT autobox evolved from the one Nissan used in other vehicles - the Pathfinder, for example. It wasn't engineered or designed specifically for the TT engine's spec's.
If you search the NTB's, you'll see that the early TT autoboxes had problems galore, and required significant mod's during the first three or so years of production. If you search the Technical Forum, you'll spot many, many examples of autoboxes failing even with stock engines. That helps to explain why most people don't even try to mod the stock autobox, and opt for some really heavy duty aftermarket units that are available. Kyle Puckett used to have the fastest Z32 auto drag car and used aftermarket boxes exclusively.
