| Subject |
Re: Timing Belt, Injectors, Clutch replacement and more |
| Posted by |
CmyZ on December 21, 2009 at 12:04 AM |
This message has been viewed 73 times. |
| In Reply To |
Timing Belt, Injectors, Clutch replacement and more posted by oherr on December 19, 2009 at 05:40 PM |
| Message |
I would pull the motor, that way you have easy access to everything.. if its an N/A its easier than a TT.. then you can also do the waterby pass and EGR delete.. valve covers, knock sensor, timing belt, clutch, rear main seal, oil pan.. etc...etc....
| Follow Ups |
Post a Followup |
