TwinTurbo.NET: Nissan 300ZX forum - Question concerning OEM vs "colder" plugs
Subject Question concerning OEM vs "colder" plugs
Posted by LJZTT on December 20, 2009 at 7:25 PM
  This message has been viewed 186 times.
Message I am really learning a lot of lessons here concerning departing the safe waters of stage 3-ish for more power. Yikes what a headache this can be.
Ok so I read up about the sparkplugs, heat ranges, etc in search, and I gather that the NGK PFR6B-11B is what I should be using in my TT at 1bar of boost. My question is, what is the result of using the stock plugs at this boost level? Meaning what can I expect to experience symptom-wise?
I ask because I do not know what plugs are in it right now, and when I test drove the car last night I noticed a sort of hesitation/cut-out/powerloss/stumbling once the boost levels approached 14psi.
Also, assuming I do need to change plugs, why shouldn't I use the "7" heat range plugs recommended by Specialty Z?
[ http://www.specialtyz.com/engine_sparkplugs.htm ]
click for photos by SnowmanZ
"The American people will never knowingly adopt socialism. But, under the name of "liberalism", they will adopt every principle of our socialist program, until one day America will be a socialist nation, without ever knowing how it happened.... I no longer need to run on the Socialist Party ticket because the Democrat Party has now adopted our platform."
--Norman Thomas, 1944 Socialist Party Presidential Candidate
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery."
--Winston Churchill
