TwinTurbo.NET: Nissan 300ZX forum - There are two 10mm philips head hex bolts holding the
Subject There are two 10mm philips head hex bolts holding the
Posted by zgene4 on December 20, 2009 at 2:20 PM
  This message has been viewed 132 times.
In Reply To How to remove internal fuse panel to get to blower relay? posted by doug8867 on December 20, 2009 at 11:58 AM
Message panel to the sheet metal. You'll also need to unbolt the hood latch lever because the cable routes across the front of the panel. I'm pretty sure once I had all of the harness connections removed from the front and sides of the panel, the only one left was a single on the rear that gave me a little trouble. Unscrewing the fuel pump relay and time control unit bracket also gave me a little more slack on the main harness when trying to get all of the connections separated.
Hope that helps.
WARNING: I lack industry backing
