TwinTurbo.NET: Nissan 300ZX forum - Re: Assumptions...are...BAD
Subject Re: Assumptions...are...BAD
Posted by Andrewhuffman on December 19, 2009 at 2:09 PM
  This message has been viewed 110 times.
In Reply To Assumptions...are...BAD posted by ZTurboFan on December 19, 2009 at 10:55 AM
Message I verified compression on #2 only when i said i had compression. At 100 psi, i assumed lack of lubrication and lack of being broken in, it would increase.
You are correct, a timing belt check is next on the list, but you forgot about a possible lifter malfunction. If one or some of the lifters are stuck open, It wont allow the valve to fully close.
