TwinTurbo.NET: Nissan 300ZX forum - I agree with kickerzx ......
Subject I agree with kickerzx ......
Posted by zx299 on December 18, 2009 at 3:27 PM
  This message has been viewed 99 times.
In Reply To Re: Did you do any work on the car before this happend? posted by MaxxAction on December 18, 2009 at 02:56 PM
Message I think you have a fuel problem. Sounds like you're running too rich.
You need to check your adjustable fuel regulator, and also check your injector latency. Have you checked for leaky injector/seals ?
It runs better when cold because your motor needs choke anyway so running rich doesn't matter.
Your timing varies because your rpm is changing. As the revs rise, timing will increase. If your rpm & load stay the same your timing will NOT change.
"If you own a 300zx, you don't have time for a hobby"
"If you own more than one 300zx, you don't have time for a life"
